replace heater core
goatboy
missouri
does anyone know how to replace the heater core on a 71 dart swinger? We are confussed and I thought I would ask before I destroy anything. thanks
Pull out the heater box from under the dash, You need to disconnect the hose and cables to it and un bolt the blower motor to pull the box. The box is 2 parts and held together by metal clips. Pop the clips and the box comes apart, you will see the heater core.
You ssould replace the seals while you have the box apart. You can pick them up off of ebay.
