I have a very low budget 360LA in my bracket car. It was just a junkyard motor that I did some headwork on as well as a cam change and 4bbl intake with holley. The thing is pretty tired now but has been running 7.90's in the 1/8th mile. Here's my question....I see junkyard 5.9 engines available at a decent price. I assume that the compression ratio is higher than my factory LA @ 8.5:1 and they must have roller cams. Is it worthwhile to buy one of these to replace my current setup. Keep in mind that it is race car only, but only a few times per year with the grandkids. Will my headers fit? What about intake, water pump, transmission, distributor, etc. Right thought process or should I drop the bucks on rebuilding the LA?
Thanks in advance for any input.
