Replacement manual steering box
Racngrn
Active Member
Maine
Hi gang. New to me 70 Dart 340. Great car, but steering was very heavy- very! Car has 225/60-14 fronts, which were low on air. Increased to 34 lbs, but still a bear. Checked ratio using lock to lock and found she has a 16:1 box. That certainly would add to the effort. Looking to obtain a new 24:1 and wondering what the best source might be. Also, looks like the steering shaft can stay in the car when I r+r the box. True? Appreciate the help.
You'll have to unbolt the column from the firewall and dash and move it back to remove and replace the box. Won't have to remove it completely. Can't remember exactly what a 70 Dart has, but likely will have to remove a roll pin where the end of the steering column shaft goes over the gear box. And of course remove the pitman arm. Puller and BFH can get that off.
Thanks guys. Will that ratio provide enough relief? I can imagine it’s a sweet spot for the ratios, but at 67 ( albeit at the gym every day ) I’m worried about the coming years. Thanks
The R+R looks to be pretty straightforward and there’s plenty of room thanks to stock manifold.
I'm 74 and I have a 20:1 box in my 65 Barracuda, and am about to put one in my 67 Barracuda. Trick is NOT to try to turn the steering wheel unless you are moving. I.e., don't back up and stop with the wheels full lock in the opposite direction you want to go. Learn to straighten up before stopping, then moving forward before turning the wheels again.
Parallel parking can be a beach, though.
Try here.
Firmfeel Mopar Suspension and Steering
Very helpful info. Is there a downside to the 24:1 that I should know? Vague steering down the road? Something else? I’ve seen the PST box and they are well regarded. I do like that I can get a 24:1 that is stock appearing ( original casting). Kinda into stock appearance. Thanks
Steering column has to come back far enough for the coupler to slide off the input shaft of the steering gear. I like the 16:1 box myself....for the open road. Not so great for slow turns or parking. The 24:1 box is just too much understeer for my taste. You could always convert to P/S of course. That keeps your steering ratio about the same.
PST 20:1 box (from Mancini Racing) bolted to the K frame that's going into my 67 Barracuda.
evidently we got a buncha pirates around here with peg legs and hook hands the way everybody wants power brakes and noodle arm steering.
chopper read says: harden the **** up, ya buncha nans!
My dad drives a 68 dart. qa1 K-member with sway bar. Qa1 uca and lca, pst thicker torsion bars, kyb nitrogen shocks, 15inch wheels, 24:1 steering box. Drives like a dream, handles amazing and little effort. On the other hand I drive a 69 dart same front setup but with a 20:1 steering box. More effort especially in a parking lot lol
I've got the QA1 front suspension stuff with sway bar and their shocks, with a 16:1 PST box on my slant six 65 Valiant and now that I've got torn rotator cuffs and other old guy ailments I'm seriously considering a Borgeson power steering setup. Maybe I could ghet by with the 20:1 box though.
Do the pirate...Do the pirate! :)
Like said, manual steer is great in an old Mopar going down the road! their PS has NO feel. Like said, Yes parking is a bear and car needs to be moving to handle manual steer. I have had many 68-70 Roadrunners with a BB and manual, I prefer it.
Yes old steering boxes can wear, and they can al;so require grease an service! and if you have never driven one, it is different! like carbs vs f.i.!!!
