Mopar King
Beginner / Need of Help
I been curious and wanted to get some imput on the modern plastic body master cylinders in mopars. I know that you need an adapter plate and the bore size is the same as the stock M.C. which is 1.031
Im thinking of getting one to test out. I have a 1972 manual disc brake with proportion valve just under MC - dodge dart that i want to clean up. thanks
I liked how daniel_depetro has it set up from slantsix.org - that where I got the idea
http://www.slantsix.org/forum/viewtopic.php?t=47497&sid=e187428ada6c8bd250aae7713ee74c40
- do they perform the same as a cast iron one?
- any safety issues? don't want to fall off a cliff
- can these hold more fuild than the cast iron ones?
- are all modern M.C. the same? looking at dorman's M99294 and C.P. M-83028
- I know that most of these are for disc brakes only but do they have one for drums? or can it be used with drums as well?
- any problems with the caps? keeping pressure and staying close tight
- any leaks or weak points?
- any change of size in brake lines?
