replacing motor mounts, have a few questions..
durdybert68
Assfault Junkie
Cincy
need to replace the driver side motor mount on my 68 Dart GT. Pretty sure its rocking the factory rubber ones right now. Are the pass/driver side the same part? Any suggestions on type of mount I should use? dont want to spend a fortune but looking for a reliable part. Thanks in advance!!
Right and left is the same part on the small block engines.
$3.99 is our local price for just regular mounts made by Anchor.
http://www.oreillyauto.com/site/c/s...ge&model=Dart&vi=1087815&keyword=engine+mount
They SB ones aren't the same in 1965, but I think 1968 is different. Do you have a 273? You didn't bother to tell us.
Unless you know the pass side is new, I would replace them both.
While your at it change the trans mount.
All new mounts are nice.
yeah its a 318 block and I am planning on changing them both out and will probably do the tranny mount as well.
