[SOLD] Reproduction Factory Style Right Side Exhaust Hangers
slant six
Do More With Less
IRWIN
For '67-'69 cars for sure - Maybe Fits all the way to '76 as well.
I have installed a set of these reproduction GTS Style Tip Hanger and Right Side Pipe hangers on my '69 whan I added dual exhaust.
Drill imprints for the brakcet are under / Behind the Rear Seat in the Floor / Trunk Stamping in the sheet metal, and there is a square slot / hole to add a 5/16" J nut to the Right Frame rail for the tip hanger. Pretty fuss free way to add the right side Pipe to a slant 6 or 318/273 Car.
Parts may Fit '63-'66 cars as well, but I have never fully investigated that, so do your research.
Asking $50 plus Shipping from 15642, PA to you.
The Primed muffler hanger floor bracket is in a bag with the 3 locking style nuts. It has never been opened or used. Th bag is t bit tattered from shelf wear etc.
The Tip hangar had some surface rust from sitting around, I Cleaned it up in the bead blaster so you can paint or coat it to match your car as needed.
