dwhip361
Awhile back I converted my 72 duster 4 wheel drum brakes to front disc. I used a master cylinder from a 73 disc brake car and put in an adjustable proportioning valve for the rear. I don't have the original proportioning valve. The problem is that the rear wheel cylinders are new and have leaked from day one. I read that the master cylinder is supposed to have the Residual pressure check valve built in. Is this true and could the lack of one cause the cylinders to leak? Thanks for any help.
