White Lightening
Member
So my question is straight forward,
I want to know how much can say, stock 318 heads take before the retainers start knocking on the stem seals.
How can I increase the retainer/seal clearance?
What's a good rule of thumb for camshaft lift in relation to valve spring open pressure/closed pressure? (Particularly with mechanical flat tappet camshafts)
How do I know if the machining die is the right size for resizing spring cup diameter?
I'm asking a lot of questions, but I hope that if any one does a quick google search and they come across this thread it can help guide them in the right direction; either to their engine room, or to a professional machine shop
(which is in lacking supply in Alaska)
