USCG CHARGER
- Joined
- Apr 25, 2007
- Messages
- 2,486
- Reaction score
- 50
Going with a new look in performance in the next few months. A few small details are:
416 stroker
R1 block 4.070
4" dragon slayer crank
Carrillo Rods 6.100
Custom CP pistons 9.5:1 static (.040 quench)
Billet Mains
Block was prepped by Ray Barton
Phil Colman ported W9 heads
Ferrea 2.18 valves/ 1.66
PAC springs
Mid 370's flow at .700 (I don't have the flow sheet my builder does)
Custom turbo cam (most likely non split or even reverse split duration) 240's with a LOW 620-640 lift.
T&D 1.6 rockers
custom pushrods
W9 single plane intake with injector bungs
90* elbow with 90MM throttle body
Power adder:
Twin Turbo Borgwarners 68MM
TiAL waste gates and BOV
Water : Air intercooler
All plumbing will be Stainless
Lazer cut W9 flanges
Front Suspension:
TSHELL tubular K frame with rack and pinion, and QA1 coil overs.
Rear Suspension:
Virginia Rod Company fully adjustable large Tri-4 link
Custom Nascar 9" stamped housing, detroit locker, 3.50 gears, 35 spline axles.
Drive Train:
Custom Drive shaft local company.
TH400 trans
Coan converter
Trans brake
(Don't bother asking about the trans as I got it for a hell of a deal with the TC and it's never had a pass made) Built for 1500hp.
Wheel/tires combo:
Billet specialties 15X10 (3.25 BS) 325/50/15
Moly cage and subframe connectors
The car is already painted and interior is complete with custom door panels, dash pads and visors, including all new bezels.
Fuel supply.. unsure? Definitely doing a 15 gal fuel cell in the trunk.
E58 fuel
EFI as of now I'm going with Big Stuff3 but will purchase that last.. I was looking into the MS3 too.
This car will be just a hot rod to go show off at the local cruise ins and car shows with seeing track time once or twice a month. I would like to be able to drive the car to the track run some nines a drive it home. 50 miles one way!
Goals are make over 1001 rwhp, be streeable, be different, run low 9's
The fun starts tomorrow with suspension. Looking to complete this project by end of March. I will take lots of pics as I go starting tomorrow. I volunteer at VRC a race shop/fabricator so I'm going to do as much of the work as I can (safely).
Mopar or No Car!
416 stroker
R1 block 4.070
Carrillo Rods 6.100
Billet Mains
PAC springs
T&D 1.6 rockers
custom pushrods
Power adder:
Front Suspension:
Rear Suspension:
Drive Train:
TH400 trans
Coan converter
Trans brake
Wheel/tires combo:
E58 fuel
Mopar or No Car!
