Reverse/steering lock linkage?
Airfix
Cloverdale BC Canada
Trying to assemble my car today, bought it on pieces so finding some stuff missing and not sure how it should look.
Iv'e got the reverse/steering lock stuff, I can see the shaft bracket is supposed to bolt to the drivers side frame rail clsoe to the Z bar for the clutch, but I can't see how it attaches on the other end (towards the bellhousing) any idea, pics would be great.
Iv'e looked at Year One and all the other websites plus my manual and can't see anything, the crossshaft looks like it should fit into the bellhousing, there's a hole in about the right place but the shaft is too big.
Any ideas?
Thanks.
Sorry if I am a little confused by your post. Are you asking about the clutch z bar support for the bell housing ? If so, those are bolted on to the housing with two bolts. The pivot or ball for the z bar is riveted to a flat 3/16 or 1/4" steel plate, which the bolts go thru. Try contacting brewers and see if they can help you.
No Z bar is o.k. it's all bolted in, I mean the linkage for the steering lock on a 4 speed car, selecting reverse moves a pushrod and linkage to rotate a collar on the column. it's the cross shaft on that monkey motion that I need info about.
