Ride heigh help
tguss
columbus ohio
Help with ride heigh , the bolts under bottom aarm that you turn to lower or raise front end are the bolts dispose to be turned equal turns from each other ? I adjusted mine and one bolt looks longer , is this right ?
get the car on level ground and measure from the bottom of the ball joint on lower control arm and from the upper part of lower control arm to the ground, just make sure both sides measure the same.
