tguss
Help with ride heigh , the bolts under bottom aarm that you turn to lower or raise front end are the bolts dispose to be turned equal turns from each other ? I adjusted mine and one bolt looks longer , is this right ?
I wouldn't crank on those bolts with the weight on the suspension.
