Ride height adjustment bolts
Sweetjones
Louisville
Recently I rebuilt the front end of my 75 duster. All brand new parts. To make a long story short I have about 1/4in difference (one screwed in further than the other) in my ride height adjustment bolts. Is that enough to effect the ride or make it hard to adjust camber/caster? The ride hight from side to side on the car is very close maybe an 1/8in of each other. Do the torsion bars need to be re clocked? Thank you!
These cars aren’t balanced perfectly left to right, so unless you actually tried and succeeded in setting the corner weights the same the torsion bar adjustment isn’t going to be perfectly equal side to side.
Obviously a large difference could indicate a problem, but a small difference would be more common than them being exactly the same.
