Ridgid multi tool
dennday67
Yakima, WA
I bought one of these today to scrap the under coating off my Valiant and it worked better than I could have hoped. It also came in handy cutting out some rusty sheet metal. It didnt cut as and easy as a die grinder with a cut off wheel but the cuts were tight and no sparks.
I had wondered if those things would cut undercoating. Thanks
It worked well with the bosch scrapper. It was the same price as the dremel but it offers so much more. Built in led, adjustable speed trigger instead of a dial, you can rotate the head and change the head to 5 different tools, decent case, and has a 3 amp motor which is more than the rest ive seen.
