mopar4x4stroker
Coming down home stretch w/ my build... I know, I aint been on in a while
ops:. Been working like a mad man. You guys probably forgot me by now. I'm the kid building the 408 for my 86 4x4 w/ O/D as a DD/weekend tower/wheeler. It'll be mostly city.
I need help deciding on what ring manufacture and or material to use. My machinist will be finish honing for molly's. My question is should I go hastings, selaed power, speed pro, total seal, childs & albert, JE ect? Should they be cast, ductile, plasma? Cast are $30 Plasma are like $115(big price diff). My pistons are keith black KB416's w/ 5/64 5/64 3/16 ring lands.
My next question is break-in procedure....
I've been told you should drive it like you stole it after initial cam break-in and oil change. I've heard if you break it in like a pu$$y it'll run like a pu$$y. My only concern w/ that is, this is my first motor and trans build. I dont care to go tear up 9k worth of parts in less than 5min. I dont want a bind or a flare up on FT pull. My shop is on a road thats 40mph, I can safley exced to 60 or 70 if need.
Whats better for fresh rings, high RPM or heavy load? In other words would a full throtle pull (w/o kick down) from 2nd-3rd be better than just romping on it in 2nd gear to 3000-3500 rpm and engine braking to 1,500 over and over? Or would EB be a bad idea, as in induce blow by. I would think the EBing would push the rings out aswell to help seating?
How do you guys suggest I break it in.
Thanks
Thanks
