funkyflynz
Still waiting on Bill to answer some questions for me, maybe hes away or busy, so thought i would ask those of you running the RMS AlterKation kit....
1) running there standard ride height setting how much travel? How much compression, how much drop?
2) How far from the ground will this put the front frame rails where the cross member bolts to the frame?
3) What is the track width with wilwoods installed? Point where wheel mounts.
4) Does the system use bumpstops?
5)Can I run wildwood 2 drop spindles?
Thanks guys.
Lee
Thanks guys.
Lee
