Snake
Mopar Nut
Un real.
Or, is the bolt snapped off in there?
Arent the torque specs wrong in factory service manual for those too?
wow...so many things that could be said, but would probably hurt someone right in the feels.
My brothers friend is the guy that assembled the engine but he had a couple different shops do the machine work.
Go ahead ... we're all relatively hard-skinned here. ;)
Your momma was there went you left your right.....
Maybe some of you
I was going to say something along the lines that the friend need to learn how to read a Mopar engine book. It doesn't require a huge amount of familiarity, but it does require comprehension and maybe to give a **** about what you're doing. Any clown shoe who knows how to spin tools to assemble an engine knows when a bolt breaks and if it does, remove the broken piece. You might even want to look at the piston rings to make sure the gaps are correct and they're in the right lands...
