Rocker Arm Identification????
emnestor
emnestor
Va Beach
Can anyone ID this odd rocker arm I found on a 340?
I recall that my 2002 3.8L has stamped steel rockers like the LA engines, so no telling how long Mopar kept that design. Don't know if they interchange.
The rocker on the left is standard but the one on the right is odd and it is the only one that looks like that.
Yes, that is a Charles Racing Aluminum Products rocker arm....or CRAP for short.
Just kidding, I have no clue. :D
Search for photos of Magnum engines, both V-8 and V-6, 3.8L, and other Mopar push-rod engines. I don't know if any non-Mopar used stamped-steel shaft mounted rockers. A co-worker recently mentioned that his 63 Cadillac engine was special, with shaft-mounted rockers.
As I recall, there should be round washers between each rocker arm to space them and avoid rubbing. Perhaps they aren't visible in the photo.
This 69 340 has all standard rocker arms ( left and rights) except for two that look like the on on the right. just trying to figure out if they are a replacement aftermarket product or something that is just completely incompatible.
