kyles73dart
Can anybody tell me the torque spec on the rocker arm bolt for a 360? Thanks
All the books say 30 ft. lbs..
Mine were streching on a set of X heads I installed and I just replaced them w some grade 5 3/8x16 bolts from the hardware store. They torqued down fine @ 30 ft. lbs. After a closer look someone has drilled and tapped these heads to 3/8-16.It is a 5/16-18 and the torque for a grade 5 bolt is 17 ft pounds dry.
They aren't 3/8 bolts in a std SB head.
Have at it. I'm done.
For the OP, measure the bolts, confirm diameter and proceed.
I was wrong at 25 and strokerscamp is right at 15. I finally read my book and it made me smart again.I always go 15 LB FT with red locktite and never have a problem.
I retract my earlier post, but that info didn't come from mymopar.com. I found my old books and they say 17 ft/lbs.
