rocker panels on '68 dart GT
Dude
Member
winnipeg
Can somebody tell me that where the rocker panel meets the rear quarter on my '68 GT, did the factory have a lead fill to connect the two, because Im cleaning it up to install new quarters and at that point I started to cut some of the rocker and..... no sparks, almost like a silver solder for about 3-4 inches, what gives, and if so I guess Ill have to cut more rocker out and replace, the rockers are Mint on this thing.
The rockers connect about 2-3 inches in front of the quarters. If you're into the lead there will not be any sparks untill you cut through the lead. Try grinding the lead out. Might wear a mask!
