Just finishing installing the inner valve springs and need the rocker shaft stud torque specs. Heads are Edelbrock/indy TA's, comp solid .540/.547. not sure of the rocker or shaft manufacturer, but they are 1.6 rollers(blue in color), (3/8?)studs with thick flat washers and nuts.
