Just get the proper length soid pushrods and all the valve train gear for the swap.
IMO, a backwards move.
cant remember but i think you have to use the roller pushrods because top end oiling is different and roller pushrods are hollow and fed by lifters to get oil to top not thru the pedestals
roller setup oils through the heads down to the cam, regualar hydralic cam gets oiled just by the crank slinging oil
No it doesn't, you have it backwards. The oil comes up from the pump to the crank mains, than up to the cam bearings and lifter gallerys. On the Magnum roller cam there are no holes drilled through the cam that would send oil to the head through the head oiling gallery. The casting is there and can be drilled to allow LA style head oiling but a machine shop would be needed as it cannot be done with a hand drill. The Magnum head has oil supplied from the lifter and hollow pushorods which then drains back to the pan from the head.
Both the Magnum and LA cam lobes are splash lubed.
Just thought I would let you know the real deal as knowledge is power.![]()
Sounds like a roller block needs roller heads, cam, and lifters.
sorry but were not taling about magnum engines here were talking about preroller la and roller la. they made roller engines before the magnum
so i was right about the pushrods and oiling
You can use the Magnum style heads on the old LA block but not vise-versa. Reason being the LA heads oil thru passages in the block that sends oil to the rocker shafts where the Magnum oils thru the pushrods. There are no passages in the magnum style block. A machine shop can drill them but its expensive and the engine has to ba apart.Can a flat tappet cam and heads be used on a roller cam 318 block?
could ya run both systems on these blocks and a high volume pump and stay real wet
I haven't seen hollow cup and ball pushrods yet for an adjustable LA style valvetrain, but I suppose it could be done. No real advantage to it though.... I'd prefer to keep the oil down in the crank and rods.![]()
Doesn't matter, no SB Mopar oils from the head down. Nor does any BB Mopar for that matter. Sometimes the gallery was drilled on the early roller blocks as crackedback and Velentek said earlier. We are just politely trying to help wedgie get what he needs. :read2:
