Roller cam setup?
solid or hydraulic rollers.
the best price you are going to find is chet herbert racing...
lifter are around 250 or maybe less....otherwise roller lifters are about 500...
cam....chet herbert again is the best price...compcams roller cams are around 300 bucks....
then you will need valve springs....and bronze gear for your intermeidate shaft...
hydraulic
I will check out chet herbert
