Roller Lifters
SSing
upland, sweden
Hi,
I´m going to use these lifters with a Roller Crane 290 in my Nostalgia Race Hemi Build.
Not installed yet, but my concern is the bar tend to stick. I was thinking of smoothen edges of, or is this not gonna be a problem when assembled, lubricated and pressure from valve springs are applied...
What do you say? Was it ever a problem with these, what I believe early type of roller lifters. I have no experience using them.
Car will only see Nostalgia Races and Exhibition Runs.
Advise is appreciated.
Thanks, Stefan
Hi,
Thanks, Stefan
those were created to be able to change cams w/o pulling the lifters out. very outdated really. why cant u just deburr the part that is making them stick?
Yes, like I say... these my work perfectly fine when in the engine without any mods...
It´s well over two fot per set to work over, plus assembling the springs off and on, and I only do that if someone have experienced trouble with this early typ lifters
i hvae some of them and they will self clearance which is not good, so deburr ahead of installation. it's not hard to do or time consuming.
Yes I see what you mean. Of cause there will be metal dust in oil, if they don´t move smoothly, witch they like you say apparently don´t do.
Is a fine paper enough, or may be a hand tool is faster and more efficient?
Thank You for you advice.
