71_dart_swinger
so guys were can i find some good roller rockers for a small block, but im not looking to spend 500$ either so if any one knows i could realy use them thanks guys
Are the Proform rocker arms any good? I have a set of 273 adjustables & a new set of Isky ductile iron adjustable rockers. Would the Proform rockers be better or should I just use the Isky's & call it good?
71 Dart Swinger, go with the Cranes as Rumble suggests or stick with the ductile iron adjustables.
'64 Cuda, the proforms suck. The adjusters sef-destruct and the rollers flatten.
Cranes must be installed with only one to two threads showing below the rocker to assure proper lubrication of the adjuster and pushrod cup. This is done by making an adjustable pushrod, measuring it, and having the correct pushrod made or by matching the length up with an exsisting new pushrod.Cranes have had they're issues with the adjusters too...
I would definitely make or purchase an adjustable pushrod that will allow you to get the correct pushrod, for your engine and heads the first time around. On a magnum style head, pushrod length will determine where the roller contacts the valve stem face.Thanks! No use in asking for trouble.
Does anybody sell "out of the box" pushrods to fit between Magnum roller lifter & an LA adjustable valve train? I see that Crane sells one to fit their setup but I don't know if Crane roller lifters are the same height as stock Mopar magnum lifters.
