Just run the right lifters. MRL sells them.
im pretty sure the mrl lifters nomather how great they are might have a maximum lift aswell before they run into a oiling problem aswell can we please get back to topic.
what is the best way to measure how much lobelift one can use before getting into trouble with rollerlifters and the oilgallery problem?
I thought the topic WAS the location of the lifter oil groove. The MRL lifters have a lower oil groove and eliminate the problem as rumblefish said.
If that's not on topic, then forget I ever tried to help.
As stated , you need to know where the base circle of the cam sits. If you know what cam you want to use, then just purchase it, test your lifters on it and if they are no good then get ones that fit.
Then do it your way. Why the hell are you even asking us then?
Sure I read it. It's not an uncommon or unknown problem. It is also something that will vary from block to block.....even lifter bore to lifter bore. Why? Because some lifter bores are chamfered on the inside top edge reducing the amount that the lifter can come out of the bore before it exposes the oil groove. It's not something you can simply measure once and have a definite answer because of all of the machining differences. I have seen blocks have about half chamfered and half non chamfered bores, all chamfered, a few, or even none at all. So it simply depends on YOUR block. No one can answer your question but you. BUT we CAN offer a viable alternative that will WORK. Those are the MRL lifters. You've been informed about them, yet you keep shooting it down. SO, have fun with yourself.
And as for you being unappreciating, I can't argue with you there.
Let him cry and whine on Rusty. He'll either figure it out or not d o it at all. He thick, that's all.
I'm with you Fast. See know reason to have your balls broke for what you asked. Plenty of motors been running comps for years. Long before MRL rollers existed. Can you pull one the galley plugs and at least look at the end rollers? Since you have rockers if there is an issue I'd check into bushing the block. Better to spend the money there in my opinion.
Hydrolic or solid? I have a set of the older comp solid rollers in one of my 340s. Oil pressure was lost at around .600 lift. The engine was already done when I got it and runs plenty strong. The builder ended up going with a .555/.566 comp cam to be safe. Pretty mild cam for a solid roller, but that is all the lifters would safely allow.
