Frnknsteen
Hi Guys,
Picked up some new seals and a new hood insulation panel for my Barracuda at the nationals last weekend. I've got the cowl to hood seal and the radiator to hood seal installed just fine.
I installed new roof rail seals and I'm wondering if I have them in there correctly and how the window is supposed to sit on the seal. When the window is up and I close the door, the window hits the outer part of the seal and holds the window out some. You can see a gap between the door window and the quarter window.
When I close the door with the window down, then roll it up, the gap goes away and the window tries to go under the lip. I figured that is how it is supposed to sit, so I closed the door and reached through the vent window to roll it up the rest of the way while pulling the lip over the glass.
Wondering if this is how it should sit (in pics below) and if they will eventually take a set like this so the glass pops under when the door is closed with the windows up?
