ROOF RAIL WEATHER STRIP HELP
cawley
383 Bcuda
milton
Where do you guys buy your roof rail weather strips ? I have a 69 barracuda FB. I bopught a pair from a place called Metro. They don't fit, they are just not right. Also the rear side window seal isn't right.
Believe it or not found my window channel seals on rock auto in the universal parts section around $1 a foot, just have to measure the old to get the dimensions, looks oem.
Soft seal has them and is a sponsor also.
Is it them or Supersoft (Metro) that is (or was -I don't see their ad)a sponser?
Body Weatherstrip Windshield Molding / Seal Parts | RockAuto
Just look through all the sections for the one you need.
I see a lot of Metro (Supersoft) listings there. I did not realize they were two diff companies. I used Metro on my Duster Seals good but some areas are too soft. No re-enforcement for pieces that screw on. Originals were tougher rubber and had metal imbedded. I see my uppers listed (roof rail)where my window seals, but no listing for lower door on Soffseal.
Does anyone else make this stuff?
Mine had to 'take a set' through a few hot days before the corners of my Duster side windows would seal. And did a lot of adjusting to get contact over the whole thing without gouging the extremely soft seal in other areas.
