" Most " of the time the rust issues will not be on the seam but around the front and rear glass, and along the trim ...... Make sure when looking to feel and push around the glass edge to look for any bubbles.... if its not to bad it can be fixed pretty easily.... But if its like mine you better run from it...... The seams if not rusted are a pretty easy fix.... You can also add a padded top to hide some of that seam if its not perfect....
This is what you dont want !!!!
My '73 Duster has that problem. It had a vinyl top and it was taken off. The bondo is starting to chip off and etc right at the seam. Everywhere else is fine though. Now I need to fix it right.
What with all the flexing etc that I am sure the roof sees, would you have to lead it to do it really right?
The factory was even sloppy with the lead on non-vinyl top cars.
You don't have to use lead to repair it. Remove the old filler. Optionally, weld the seam solid. Fill with "USC All-Metal" filler or similar. Finish as necessary.
