Yes, it will fit, no problem. All 67-76 k-members can be swapped from car to car. The 73-76 k-members have spool engine mounts and sway bars that pass through the k-frame. Which to some, the 73-76 style K is a little more desirable. But to answer your question yes, it will fit.
Try to avoid the 67 K frame. It has a one year only (and more expensive) Idler arm. If you install it in a later A body, you will have to use the 67 style arms.
