Here you go; 73 Dart Sport - same as the Demon.
Use the front bumper bracket mounts and the rear bumper bracket mounts. Diff. adapter plates are needed. Mike
Nope; plenty stong. The shell only weighs maybe 6-700 lbs. We did all the panel work, on its sides, upside down....just spin as needed. The frame connectors were added and tack lightly welded with the car inverted. I then went onto its sides for complete welding of the connectors.
Not, its not done. Its all jammed out in B5 blue, exterior in blue tinted epoxy primer. I'm sure it will align fine. What you need to remember is that these cars have tremendous variations, car to car, and there is so much adjustablility in the fender/hood/door fitment...that panels will be fine.
there is also a ton of adustability in the front end....and tons of built in factory slop. remember, these were CHEEP cars. They weren't straight from the factory!
I'm totally confident that there will be no alignment issues. As I stated before, the car body was inverted, so the stresses were "in plane" as far as the body was concerned when the connectors were installed. Final welding of the connectors (filling in missed areas) was done with the car on either side.
