Snake
Mopar Nut
Now I AM ready to install the rotor seal. witch way does it go in,is it the first pic or the second pic.? thanks again.
Make sure you clean the grease from the edge too. You get that stuff on your brake pads and they won't work very well.Now I AM ready to install the rotor seal. witch way does it go in,is it the first pic or the second pic.? thanks again.
Wrong.Tap that bad boy in until that lip is even with the rotor. Other that that it looksssssss good!
So i did it right great,thanks.Wrong.
Seal is installed correctly, in the picture.
I just fount the old seal what a difference in the old and new.]
Really, nothing.
Just a difference in the manufacturing design to the seal.
Both styles, do all the same thing.
