2kids
Hi folks,
Heres the pattern on my 71 Dart .I think its a carb/choke issue?
Its variable, sometimes it will start on the first start of the day without even setting the choke, other times I have to actually pump the gas pedal while cranking it over in order to get it to start.
Then, if Im running a few start and stop errands it will start to struggle to start up and I usually have to let it sit for a few minutes and then pump the gas pedal while turning it over to get it to start.
Yesterday it started up after pumping the gas pedal while turning it over and it was running really rough while trying to warm it up. I took it out on the open road for a nice Sunday drive and it ran great the entire time, which I interpreted as maybe a carb issue.
So, I dont know just curious about what you think. Rebuild the carb? I know Ive seen vacuum leaks mentioned on other threads not sure how to check those yet but sounds like that might be in my future too.
Thanks,
2kids
Thanks,
2kids
