sniekamp
318 in a 74 dart with a 2 barrel carb. Exhaust choke coil.
Okay so her are my symptoms, start the car and it starts off fine. Pulloff works good (checked it). But after it runs for about 5 seconds it idles a little rough, doesn't die though. Then when I put it into gear, reverse or drive, and step on the gas or acts like its about to die and almost stops running, then acts like it gets a bunch of gas and takes off. I was wondering about why its idling rough and what causes the hesitation when I hit step on the gas? Also this is only when the car is started. Once i? drive around the hesitation doesn't happen and everything runs real smooth.
