RPM Manifold w/AC
cgraff
Member
Is anyone using the Edelbrock RPM manifold (sb) in conjunction with a Sanden AC compressor? If so, which AC bracket are you using? Bouchillon's bracket doesn't clear the thermostat housing and the small hose connecting the manifold to waterpump contacts the under side of the compressor.
Just curious if anyone else has run into clearance issue using this manifold with AC. I have power steering so I'm limited to keeping the compressor on top side of the waterpump.
What do you mean by old style RPM manifold and what's different about it? Also, what AC bracket are you using with the Sanden compressor? Got a pic?
