Rubber sway bar bushings
Suspension, Steering and Chassis
  1. demon67
    demon67 Well-Known Member
    73
    11
    Sep 25, 2011
    cornwall
    Local Time:
    10:22 PM
    Replacing the sway bar bushings on my 72 Demon and wondering if anyone knows who sells rubber bushings. Not interested in Poly. Thanks.
  2. S'cuder
    S'cuder FABO Gold Member FABO Gold Member
    358
    320
    Nov 30, 2013
    Upstate
    Local Time:
    10:22 PM
    Are these the triangular bushings?
    If you find them, please post here. Poly are the only ones I've ever found. I take them apart to grease them every other year or so because of the squeak.
    According to the parts manual for 1968, they weren't serviced. I guess if you needed a bushing, you had to replace the whole bar.
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      49,528
      34325
      Jan 18, 2006
      Iowa
      Local Time:
      9:22 PM
      @PST may have them. A vendor here!
      • Like Like x 1
      • S'cuder
        358
        320
        Nov 30, 2013
        Upstate
        Local Time:
        10:22 PM
        Thanks, Mike.
        Because they're a FABO vendor, I always check with PST first.
        They're showing poly only.
        • Like Like x 1
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          10,672
          5106
          Nov 28, 2008
          NorCal
          Local Time:
          7:22 PM
          There’s no need to disassemble the mounts to grease the bushings. Next time you take apart the mounts, drill the mount for a zerk and drill through the poly bushing at that location through to the bar. The poly is stiff enough that the hole won’t bother a thing, and now you can grease the bushing any time it needs it.
          Poly is not like rubber, it doesn’t flex much so the surfaces that move against each other need to be lubricated. If the poly is squeaking it needs to be lubricated, otherwise it will wear and deteriorate. Properly lubricated it’ll outlast rubber and provide better performance.
          • Like Like x 1
          • Thanks! Thanks! x 1
