AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,933
- Reaction score
- 12,282
I wrote flexible connection,but I meant;connection of some kind.As in; able to be decoupled, loosened.
I can pull the sender back out and check that tube connection again I guess being that's when it all started. Like you said maybe it is grabbing air there.
maybe i missed something , but it all started when you fitted the leaky sender in the tank , right . so hows your filler neck cap , is it a venting type ? could your sender leak kept the air flow so the tank never came under vacuum , i know you have a fuel return , but it might not be enough . have early d series p/u's and i had an issue with a cap not venting .
If the pump does not sound good under pressure, I think the pump is at fault.
Thanks Rusty! I was going to get a pump tomorrow being I don't know what else to try. Went through everything today.
Just odd the pump runs perfect when just flowing into a gas can.
....and even more odd that it happened after youtook the sender out....but stranger things have happened. Maybe you knocked some sediment up and the pump sucked it up and became damaged. Just a thought.
What kind of inspection have you done with the carburetor? This is stupid. All from just removing the sender and putting it back. I swear......you have luck like I do.
