ValiantOne
My 273 sb, 2 bbl stock engine just started running rough at idle, and when coasting or at partial idle. Popping sometimes under trailing throttle.
Had the engine out last winter. Replaced all gaskets (intake incl) distributor, cap, rotor, wires, plugs. Upgraded with Trailbeast's hei upgrade. All was good! Ran like a champ for a few months. Now experiencing the problem above.
I widened the plug gap a few weeks back to .045, for the hei, I put it back to .035 today. No change. I tried reversing the distributor signal leads when I installed the hei. Ran crappy one way so i installed them the other way as instructed.
Just did the plug wires this weekend. No change.
I'm getting just at 12.7v to the coil.
The left bank exhaust smells gassier than the right. Seems ignition related. Not sure what to check next?? Maybe plug wire resistance?
Any thoughts?
Thanks
CE
Any thoughts?
Thanks
CE
