rust removal
Tadams
Tadams
nc
I have removed the exhaust and need to clean up underneath the car. Lots of rust but only a couple of rust through holes. What could I spray the would help? I have something from Harbor Freight but it says to dip, not to spray it on. I can remove and dip some things, but not the entire car. Once the rust is gone what should I use to protect the body and chassis parts from rusting again?
Thanks for your idea's.
Im sure you will get a lot of opinions and ideas here. I have had luck with OSPHO and it is an inexpensive alternative that can be sprayed on neutralizing rust.
Thanks, where would I find OSPHO? I would like to get started soon.
I got mine @ ACE Hardware ($11 qt) but google it...Im sure there are other sources.
Even Amazon carries it:
[ame="http://www.amazon.com/Skyco-Ospho-Metal-Primer-Qt/dp/B000C02CDG/ref=sr_1_1?ie=UTF8&qid=1312403051&sr=8-1"]Amazon.com: Skyco Ospho Metal Primer Qt: Sports & Outdoors[/ame]
NOTE: this stuff goes a long way.... you will use 1/2 as much as you think you would. I did my whole inside floorboard area with less than 1/2 qt!
