340GTSport
Active Member
Thoughts about eng blocks that have been board an honed that have stains in the walls from where water had once been inside ?
Run it. You'd be shocked at how much surface rust there is on engines that sit up for some time. Another example is brake rotors.Thoughts about eng blocks that have been board an honed that have stains in the walls from where water had once been inside ?
Can u please elaborate I’m not sure what you mean .If it has been bored & honed......& the stain was not removed during honing, it suggests the 'stain' might be a depression [ rust ] in the bores.
I sure don't want to argue with anyone. Imagine a ink stain in your fingerprint. That is a very poor finish compared to a crosshatch honing.
This is a good read if it works.
And it don't work. Sorry
