Rustoleum vs. POR 15 vs. others
Judge Mills
1971 Plymouth Duster
Westport, Washington
Is there a noticeable or critical difference between Rustoleum and POR 15 and other high end rust converting paints? I have been using Rustoleum in places on the frame and floor pans. It seems to hold up fine, but just wondering what you guys think.
Subscirbed.
I have been given mixed reviews on POR15 by pro's...with the cost and the mixed reviews I decided to opt out of it. After a bunch of reading it seems that every rust converter uses the same chemical which happens to be a plant extract. Use Napa rust treatment, on pitted rust areas seems to work pretty good. 10bucks a bottle and goes a long way. It also hardens really well and allows me to coat bare metal areas im working on until I shoot primer.
Interested in getting more pros take on it from off of here.
Haven't heard of the Napa stuff, I'll keep an eye out for it. We use Ospho at work a lot, which is just a rust converter, not a paint, then paint Rustoleum over the top of it. It seems to hold up, but have only been using it for the past year or so, so that is not a long enough time to tell.
If Por 15 and the others use the same chemicals, it may come down to the concentration. It's just really hard to justify buying POR 15 at nearly $50 a quart when you can get a quart of Rustoleum for under $10. 1 gallon of Por 15 is almost $150!
well, i have done alot of my own work. i tried both on floorboards, and then pet a little bondo over a pitted area, just to smooth it out, and i went to sand it, and the bondo peeled right the frig off of it. por 15 did the same exact thing. so in my use of it, what ever i put over it, reall did not stick very well to it.
I've always used duponts metal-prep and then two good coats of duponts self-etching primer. I like to use the por-15 after that. Seems to stick very well. Depending the area but floor pans and under carriage I even like to hit it with spray in bedliner for maximum durability. Just my opinion. I hope it helps in your project.
I am not a Pro, but here's a web search:
http://www.autobodystore.com/ms7.shtml :
There are many different types (or more correctly, technologies) of products you can use in the restoration or repair of your vehicle. Some have a variety of uses while others are very limited with only a few of specific uses. Proper choice of products can help you get the job done faster and/or help with the longevity of the repair.
Let’s start with some basic definitions. I couldn’t possibly know every paint manufactures terminology or product use. These are generalities and should be used as a guide only to then read the tech sheets of the products you have chosen for proper use. These tech sheets can be found at the jobber and are given away free. Or most manufactures have them on line, USE THEM. They are a wealth of information and can save you many headaches. You don’t need to read every word in the mind numbing text, they usually have a “product at a glance” or something like that will cut to the chase and give you what you need.
Basic terminology’s;
“Solvent” is a generic term and refers to any “reducer”, “thinner” that is used to reduce the viscosity (“thickness”) of a product to aid in spraying or applying. It could be acetone, lacquer thinner, urethane reducer, a special “basecoat” reducer, water, alcohol, etc. These solvents ARE NOT INTERCHANGEABLE; each product MUST be used with the specific solvent recommended by the manufacture.
“Etch primer” an acid containing primer.
“Primer” a product that can be applied to bare metal
“Surfacer” (or “primer surfacer”) A primer that has “body” or solids and is used to fill imperfections and provide a film thickness to sand or block a surface to a smooth base for paint.
“Sealer” a non-sanding product that is applied prior to painting.
“Primer-sealer” A sealer that can be applied over bare metal and then top coated without sanding.
“Flash time” the time you allow the solvents to evaporate out of the film you have applied.
Basic technologies;
“Single component” or RTS (Ready To Spray). This is a product that uses no additional components. Just pour it from the can into your gun and shoot. Examples are: Some plastic adhesion promoters and primers and even some top coats like vinyl colors.
“1K” This is a product that uses no hardener, catalyst, activator, etc. It may have an added solvent, but no hardener or activating reducer. 1K products like RTS dry with the evaporation of solvents and are soluble, meaning that they are could be wiped off with a rag soaked with lacquer thinner. They could in THEORY be scraped off and put in a can with solvent and stirred back to a sprayable condition. Of course ALL RTS products are 1K. Examples: All lacquer products, some synthetic enamel products, and some acrylic enamel products. Because of the low VOC regulations the 1K product options are getting scarce, with most limited to “specialty products” like adhesion promoters.
“2K” or “Two component” is any product that uses a hardener, activator, catalyst, etc. It may or may not use a third component in the form of a solvent. 2K products don’t “dry” like a 1K. The 2K product “cures” by molecules linking together to form a whole new compound. Most high quality 2Ks are insoluble after a full cure and will not soften when exposed to solvents like thinners or gas. Examples are urethane under coats and top coats. Epoxies, ISO free products that use a hardener, etc.
Basic tip, ALL 2K products should be mixed as accurately as possible. As a rule 2K products need a minimum of 55 degrees to cure with an ideal minimum of 65 degrees. MIX THEM AS DESCRIBED BY THE MANUFACTURE. They have spent hundreds of thousands, possibly millions of dollars developing the product, they WANT it to work as BEST it can. Do as they say, don’t become a “Junior Chemist”.
Types of products and their uses;
Etch primers (some are 2K)
“Wash” or “Vinyl wash” are for bare metal applications for the ultimate in adhesion and corrosion protection. They are very low in solids with next to zero filling qualities. Some are even semi transparent. They are usually not to be top coated with paint. You apply them to aid in adhesion and corrosion protection under other undercoats such as epoxy or urethane primers.
Benefits:
- Very thin, keeps down film build
- Cost effective
- Fast application
- Non-sanding
- Super high corrosion protection.
Disadvantages:
- Some have a very small re-coat window
“Etch primer” (some are 2K)
Typical “etch primers” have much more solids and body than “wash” primers. They are more forgiving than “wash” primers, one thing being a much longer re-coat window. They are basically used to aid in adhesion and corrosion protection as with “wash” primer. You would choose “typical” etch over “wash” if you have some paint or plastic filler as a substrate along with the bare metal. Some brands have a recommendation to apply top coats over it also. This could be very useful in a money saving or time saving is important.
Benefits:
- Easy to apply, smooth, easy to sand
- Some can be applied over plastic filler (not that you need it over the plastic filler, but if you have some, it is nice to not have to go around it)
- Some can be top coated, which can be a big time and money saver.
- VERY cost effective
Disadvantages:
- Added product to buy and apply.
IMPORTANT basic! If you have used ANY metal treatment or “conditioner” read tech sheets carefully for compatibility . The acid in the metal “treatment” or “conditioner” can attack the acid in etch primers and it can LOOSE adhesion from the metal!
Urethane primer (2K) Urethane primer is the most common primer used in auto body and restoration by far. It has good solids and fills well. It is easy to sand and can provide you with a perfect body when blocked properly. Care should be taken when applying it as to not use too much. It can shrink when applied too heavy. It is the best all around primer for applying over plastic body filler and for surfacing your work. If used properly it provides the proper film thickness under top coats and is the perfect substrate for bs/ss and SS.
Benefits:
- Easy to apply, and sand.
- Applies smooth.
- Fills well with minimum of shrinkage
Disadvantages:
- Contains Isocyanates.
- Should always use an etch primer under it.
Epoxy primer (2K)
Epoxy is a good corrosion fighter. It is has a very sticky resin and will provide good adhesion to MOST substrates. It typically has poor filling and sanding qualities (that sticky resin makes sanding difficult) . It is ideal for use as a “primer/sealer” on bare metal that requires no surfacing.
Perfect for frames and components, radiator supports, items that are sandblasted and you only need to prime and paint. You use it as a non-sanding “primer/sealer” and then paint right over it.
Benefits:
- Good chip resistance (it isn’t as hard as a urethane)
- Perfect for a “primer/sealer” over bare metal.
- Etch primers can skipped because of its excellent adhesion and corrosion properties. (although for maximum corrosion protection apply a wash etch under the epoxy)
- Provides good base under plastic body fillers (skip the etch if you plan on using plastic filler over epoxy)
- Epoxy has no isocyanates .
Disadvantages:
- Poor sanding qualities
- Poor filling
Polyester primer (2K)
Polyester is a very specialized primer used in very small amount in most shops across the country. But when it is needed, it does a job like no other. Polyester has a huge solids content and will fill 80 grit scratches in one coat or 36 grit in two or three! Urethane for instance provides about ½ or ¾ mils per coat while polyester can give you as much as 4 to 6! Because of it’s high solids, it shrinks very little. It is basically like spraying polyester putty. Look for a manufacture that has a recommendation to apply etch primer under it. I see NO reason to use polyester on a straight panel. It is for use only when you need some serious filling and surfacing.
Benefits:
- VERY high filling
- Low cost
Disadvantages:
- Very high texture
- Harder to sand than a urethane
- Possible need to purchase a large gun to shoot it.
“ISO FREE” (2K)
“ISO FREE” is a urethane type primer but without the harmful isocyanates that a urethane contains.
The problem is ALL refinish products should be used with the same care and concern for your health and others. ISO FREE is like “low tar” cigarettes, don’t kid your self, it is still VARY harmful.
Benefits:
- Isocyanate free
- Smooth, easy sanding
- Good filling
Disadvantages:
- You need an etch over bare metal before it.
Basic tips… Etch primers can be skipped on spots of bare metal smaller than a dime or so when using all primers listed.
Most “quality” 2K primers need NO sealer before top coating with bc/cc or SS when applied properly.
Sealers
All RTS or 1K sealers should be reserved to VERY low end jobs to save money. They do NOT offer the benefits of a 2k, PERIOD.
Reasons to use a sealer:
- Makes up for “some” poor preparation
- Provides a uniform color for better coverage when you apply paint.
- Helps with providing a uniform substrate for paint.
- Helps provide a better substrate when painting over a 1K primer.
- Can Help with “covering” poor prior repairs
Under collision repair conditions a shop may use sealers on every job as an “insurance” protection against problems. In a restoration environment where complete panels are primed with a 2K there really is no need to use them.
If you have chosen to use a sealer there now are a few more choices to make. First, you need to decide what kind of sealer to use. As I mentioned in the beginning, RTS or 1k could be used to save money. Why put a 1K sealer over your 2K primer (I hope you are using a 2K primer) then apply a 2K top coat? It is like the old saying, “It’s only as strong as it’s weakest link”. If you use a 1K sealer in this fashion it is like replacing a link in your tow chain with a nylon tie!
With 2K there are a few options, epoxy and urethane being the most popular. I don’t feel that there is a huge difference in the two as far as how they apply or work. Epoxy is more forgiving with sensitive substrates. It really comes down to what you feel more comfortable with. The epoxy has no isos so that would be one reason to choose it.
Now that you have decided what sealer to use you have to decide on what application.
Most sealers give you the option of a “wet on wet” (or very close to it) or a full “barrier coat” application.
The difference being with “wet on wet” the sealer is applied and then allowed a short flash time before the basecoat or SS is applied. A “barrier coat” is where the sealer is applied, then allowed to cure or at the very least to totally flash. This allows the sealer to become a barrier so the solvents from the color coat can’t penetrate it and attack the substrate.
The barrier coat procedure allows for he sealer to do MUCH more of what you choose to use a sealer for in the first place. The choice is made taking into account a few factors. How sensitive is the substrate? Or, how aggressive are the solvents in the color coat that you are applying? If it is very hot weather and you are using a slow solvent in the color coat to help it lay out, you may choose to use a sealer because you know that the substrate is sensitive and the slow solvent will attack it.
I am not a Pro.
From what I have scene por 15 is seems to be a thicker material.
It held up real well on my buddy's 70 split bumper camaro.
they say Por-15 does not do well by itself in direct sun light
I recommend an epoxy based sealer in your primer and/or final coat.
I used Ospho and then 7 coats of Rustoleum rattle can on a trunk lid -
-to no avail, it still rusted thru in a few months...
...of living on the coast of the SALTy ocean.
Years ago, after the initial purchase of "Made in Mexico" leaf springs made out of regular production steel, I sprayed 3 coats of primer and 7 coats of a rattle can labeled "flexible paint" from the local advance auto department store -10 years of neglect and it has held up really well here- some rust in a few spots but overall pretty damn good.
(notice phosphate/Ospho Petroleum/Rustoleum in the names)
I believe that older acrylic paints would not bond to the oil based Rustoleum paints but am not sure how well the acrylic enamel blend paints would do-it has been suggested by bodyshop owners that know that they talking to a low budget guy that modern acrylic enamel paints should do just fine, I have not substantiated that yet-will let you know sometime next summer after deployment.
When I worked at the explosive handling wharf ( a submarine hanger on a pier),
stainless steel, non ferrous aluminum alloys, etc. all corroded under the sea's alkaline influence-so things tend to rust quickly here - I just lost the battle with mother nature with my 78 D300 which has gone the way of razor blades (RIP 77-2011)
I am still fighting this battle with 6 other Mopars, and there will be more casualties.
Those alloys on the pier never touched the brack water from the river; salt is in the moisture in the air here.
I am going to try the marine rustoleum (which has a marine rustoleum primer-available at my Lowes store) on my daily driver soon.
I believe an etching primer is a better start for bare metal, but i would not necessarily remove all of the paint from a non-rusted surface (body shops do remove all paint as a general practice) -I don't because I find that the Ospho penetrates the paint-if there is any rust, the Ospho reacts to it thru the original paint.
wiki: ...Metal primers might contain additional materials to protect against corrosion, such as sacrificial zinc...A steel part can be rusty, for example. Of course, the best solution is to thoroughly clean the metal, but when this is not a viable option, special kinds of primers can be used that chemically convert rust to the solid metal salts. And even though such surface is still lacking in comparison to the shiny clean metal, it is yet much better than weak, porous rust. Painting and gluing aluminum is especially important in the aircraft industry, which uses toxic zinc chromate primers and chromating to add the necessary adhesion properties.
A galvanic anode is the main component of a galvanic cathodic protection (CP) system used to protect buried or submerged metal structures from corrosion.
They are made from a metal alloy with a more "active" voltage (more negative electrochemical potential) than the metal of the structure. The difference in potential between the two metals means that the galvanic anode corrodes, so that the anode material is consumed in preference to the structure.
The loss (or sacrifice) of the anode material gives rise to the alternative name of sacrificial anode. -We use blocks of zinc on our high-yield 80 steel submarines to combat the hot sea's we sail in. When we return to port, the zinc is completely coated with salt. The Trident subs here in the southeast, rust so much more in the southern Atlantic, that our budget to maintain them is nearly twice as much as those in the northwest Pacific for the same ship deploying under pressurized salt water for the same amount of time. Lead based epoxy paints protect our subs.
POR is a mixed bag. It is a cast-iron Bee Eye Itch to prep and apply and it is NOT UV stable; you must top coat it. It is expensive, its vapors are toxic and it tends not to keep well after a container is re-sealed.
However, if properly applied the stuff will stop an anti-tank missle.
My two cents: -LY
I could be slam wrong on this.....but my understanding of POR15 and similar agents is that they are NOT rust converters. They are rust SEALERS. They do not change the chemical makup of rust, they simply seal it from air. Once sealed from air, rust can no longer spread. I have used POR15 before with great results. You do have to top coat it, but who wouldn't do that anyway? I wouldn't want the POR15 to be the top coat, regardless of its ability to withstand UV rays or not. Also, the way I have always done it, was to do all necessary bodywork first to the bare metal and then coat with POR15. It has always worked well for me. It is true though, that you better be ready to use ALL of whatever size container you open, because it does not keep well even when following the instructions. Other than that, I have found that it works as advertised.
I used por on my k frame, inner fenders, floor pans and frame
Proper prep is key. Marine clean and metal prep.
4speed is right. Coverage is great.
"Bondo/filler" of all brands sticks better to bare metal.
Anytime I use the rustoleum rust converter, I then prime over. I never use the converter on anything I intend to use filler on.
:glasses7::coffee2:
I tend to be rather anal. every bit of the rust gets the converter put on it first than all the loose and heavy stuff gets taken down, than treated again. And than taken down to bare metal and yet treated again. Every coat of treatment I leave on there for about 24-48hrs. The Napa stuff seems to penetrate extremely deeply into the rust. If it is an area that I need smooth the only filler i'll use after the final treatment is All-Metal, the adhesion is scary strong, takes a grinder to take it down when its hard and doesn't rust.
This is the stuff I prefer to use..... http://www.wattyl.com.au/DIY/Pages/killrust.aspx
I found the POR15 chassis paint to be very thin....no body to it.
These parts are painted with the Killrust paint.
The drawback with Killrust is that it takes a long time to harden.....so you need time on your side. Takes about 3 to 4 weeks to harden enough that you wont leave finger prints in the paint.
