[SOLD] *SALE PENDING* NEW Heavy-Duty Steel Deep Transmission Pan for Chrysler 904 / 999
Heywodja
The Heartbeat Stops Here
Texas
Upgrade your Mopar's longevity and performance with this high-quality deep transmission pan!
Designed to fit Chrysler, Dodge, Plymouth, and Jeep vehicles equipped with the Torqueflite A-904, A-999, 32RH, 40RH, 42RH, 42RE, and 44RE automatic transmissions.
Includes a pre-installed drain plug for clean, hassle-free fluid changes without dropping the entire pan.
  • Material: Heavy-gauge Stamped Steel 3.1 Inches deep
  • Finish: Black E-coat or painted finish (ready for installation)
  • Capacity: This pan holds 10 Quarts, compared to the stock 904 pan which holds approximately 4 quarts. Aiding in heat dissipation and extending the life of your transmission.
    • Use your existing transmission dipstick, and add fluid until it reached the appropriate index on the dipstick, no need for an aftermarket dipstick.
    • If you are using a stock dipstick and tube, I would suggest replacing the old O-ring for the dipstick tube while you have the old pan removed, the O-rings are available at most auto parts stores the dimensions are .750" X .100"
    • (I have heard some folks even double up on the O-rings for the stock tubes.)
  • Included Components:
    • Deep steel transmission pan with ribbed reinforcement design
    • Magnetic drain plug
    • High-quality pan gasket
    • 1" Filter extension with mounting hardware and new O-ring for the extension to valve body seal.
    • I also have an extra gasket for a 727 which is also included
    • I am also including a very strong ceramic magnet to capture iron/steel debris *you can also attach this inside or outside the pan if you like.
  • Not Included: -You will need fluid and a new filter
Asking 50.00 Plus actual Shipping to you with a tracking # within the lower 48 States
**other arrangements can be made but we must get them ironed out ahead of time.
PayPal Friends & Family, CashAPP, Venmo accepted
Thanks for looking!
