[SOLD] SB Adjustable rocker package
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
I've got 17 complete, good 273 mechanical rockers, and 8 bushed aftermarket rockers minus adjusters. Also have a set of 8 rocker spacers, so you can make a complete set of 273s using your exiting shafts and hold downs. Looking to get $100 for the package. PM me if interested.
Thanks FABO
These are cast and need to be on a hardened shaft. Note that the "clamshells are hardened and use a soft shaft. The soft shaft will not work with the cast rockers, been there done that!
Mark, I've done it countless times on every sort of engine combination and never had a problem. The only times I've specifically used hardened shafts on these things is when I was restricting oil to the topend.
