[Found!] SB Chevy solid roller cam and kit
physixx
Edison, NJ
Some stuff some of our Chevy friend can use. I have for sale a SB Chevy solid roller cam and kit. The cam is a Comp Cams piece with Grind # 2235N/4319N. According to the cam card, the lobe lift is .773 on the intake and .705 on the exhaust using a 1.5 rocker arm ratio. The duration at .050” lift is 278/285 degrees and has a 108 degree lobe center line on the intake.
The lifters are Morel #4843 for the set of 8 pairs. They are the Ultra Pro solid roller lifters.
SBC Ultra Pro Solid Roller lifters 4843
The valve springs are Manley Nextek #221441P-16 with an inner and outer spring, are polished and have a 1.570” OD, and a .750” ID at the inner spring. These springs have a static height of 2.535” and when they were installed in the engine, the installed height was 2” and had a seat pressure of 250 pounds. The spring rate is 575 pounds per inch.
https://www.manleyperformance.com/product/valve-springs/MAN_221441P-16/
The retainers are Manley Nextek titanium 10 degree pieces with a P/N 23647.
https://www.manleyperformance.com/product/valve-springs/MAN_23647-16/
They work with a 1.550” valve spring diameter.
They valve spring locators are Manley P/N 42335, have an inner diameter of 1.560”, an ID of .635” at the valve guide, and are .062” thick. The picture only shows 15 but one was late for the party. Definitely 16 spring locators.
https://www.summitracing.com/parts/man-42335-16
The 10 degree valve keepers are also included.
All of these parts came from a running engine with no issues. The engine only had a few runs on it and very little street time so everything looks great. I would like to get $850.00 for everything plus the shipping.
Ken
Edison, NJ
@MeMikieJr show this to Creed, I buy a lot of stuff from my friend here and is a good professional member and I believe retired drag racer..
