[SOLD] SB double roller timing set
physixx
Edison, NJ
Sale Pending receipt of payment.
I have for sale a very little used SB double roller timing set that looks to be in excellent shape. Not sure of the manufacturer but the cam gear P/N is S402 and the crank gear P/N is S297. Very little wear is evident on the gear teeth so not a lot of running time is most likely on these parts. I would like to get $22.00 for everything plus the shipping. It’ll fit into the USPS small flat rate box for $10.20 and get to any of the 50 States.
Ken
Edison, NJ
I need to run the gear numbers, is this a drop in timing set for a 360 ? Or is it for any small block sir ?
