[SOLD] SB Edelbrock valve springs new
woody30
woody30
walton ny
Got these in a parts lot. Here is a set new Edelbrock valve springs that were taken out of a new set of Performer heads so a larger lift cam could be utilized. $50 plus shipping from Walton NY 13856.
Whats the outer diameter ? Installed height ? Seat pressures? Spring rate? Open pressure at what lift? Coil bind at what lift? Im interested in these springs so I need to know the specs. Or the part number so i can find out. Thanks!
install height on a eddy head is 1.80...seat pressure at 1.80 is 125 lbs...max lift is .580...
this info is available on eddy website...
Will this fit an x head using stock retainers with no mods? Interested
sorry, changing directions. However, that is a great price for great valve springs. Someone will get a deal!
They are standard Edelbrock springs so I called Edelbrock and here are the specs they gave me. .575 max lift, 1.46" diameter, pressure at seat 120, pressure open 320, installed height 1.800" compressed height 1.220". Woody.
