Hey I'm new here so bear with me. I've got that question I'm sure alot of newbies ask. I have a .030 360 and I'm curious if anyone can give me a horsepower estimate. Here's what I'm running:
"915" J heads, port matched with all casting flash removed on both sides and in bowl area. Both sides look to be work a bit. 2.02/1.60 valves.
750 Holley vacuum secondary carb with 1" tapered spacer
Victor 340 Intake port matched
1.6 full roller rockers
Comp 292H .501/.501 244/244 at .050 110 LCA 106 ICL
KB hyper. pistons Est. compression ratio 11.2:1
Scat rods
.010 under stock crank
Windage tray
The guy I bought the car from spun a bearing so I went through the motor. It is in a completely stripped 73' Duster. This combo is very close to what he was running. He claimed a fastest pass at 11.46@118, foot break 28.5" tire with 4.31 gear and a 727. He was thinking around 430 horse?
My next question is I found a deal on an 830 cfm DP Holley. If jetted properly can I run it on this motor with no problem?
Scat rods
Windage tray
