I have for sale a SB LA cam retaining plate with three attaching bolts along with a timing gear to camshaft special attaching washer and bolt. The 340 engines came with a 4th bolt on the cam retaining plate that had a hole drilled in the center for oiling. I don’t have that particular bolt but I have taken a similar grade 6 bolt and successfully drilled my own hole down the center. Worked out great. The 360 engines had a pointer type drip tab that allowed oil to drip on the crank timing gear for lubrication. Unfortunately, I don’t have any of those pointer things either. I would like to get $20 for this cam retaining plate, three bolts and cam special washer and bolt set. Plus the shipping.
Ken
Edison, NJ
Ken
Edison, NJ
