[SOLD] SB LA water pump by pass hose fittings
physixx
Edison, NJ
I have for sale three SB LA water pump by pass hose fittings and adapters for use with any later 70 and up OEM or aftermarket intake manifolds and using the pre-1970 cast iron water pump with the small diameter by pass hose. These are all cleaned and in good shape and can be used right away. Left picture. I would like to get $6.00 for each fitting plus the shipping.
I also have two 1970 and newer SB LA intake manifold water pump by pass hose fittings. One is a new brass fitting and the other is used steel fitting that is in excellent shape. Both are for use with the larger 1” diameter by pass hose. Right picture. I would like to get $5 for the brass fitting and $3 for the steel fitting plus shipping.
Ken
Edison, NJ
The fitting on the left of the left picture has been sold.
