sb lakewood scattershield $175
oldcarnut
sb lakewood scattershield , located in tulsa ok $150 + shipping
yes it will , these are $430 new , there is a block plate & boot that will be needed also but can be purchased , check out brewers performance site , they have the pieces you would need to complete the package , this was on a dirt track car & the bottom flange was ground down for clearance , i think 2 mounting holes for the block plate is mia , but this would not effect performance or use in any way. it is steel so you could repair flage area if desired or run as is, im running an automatic so this is just taking up space. block plate is $69 , hardware kit is $18 & youll obviously need the clutch fork & bracket , stock will work & they are about $90 combined for the pair . so youd be looking @ about $328 total on everything ($150 +shipping for scattershield , $178 for accessories + tax) .
